- Joined
- Mar 29, 2012
- Threads
- 1
- Messages
- 1
GPSTrip is an application to measure partial lengths between two points. With that application, using the GPS, you will be able to measure the distance between two points, is an application similar to TerraTrip, common used as a tool to walking terrain with RoadBook.
Description
In the display you will find some useful info. On the top you will find a partial counter of the distance between 2 points, below you will find the note number (number of times that you press the RESET button), at the right side you will find the sum of the total length traveled. Above the RESET button you will find the GPS coordinates (in portrait mode, in landscape mode you will not have this info).
When you press the RESET button, it will reset the partial counter and increase the note number.
https://play.google.com/store/apps/details?id=com.gpstrip
João Simões
Description
João Simões
