Additional rigging info...
This info is from “Riggers Handbook”, one of the Bibles for proper wire rope, and other hardware.
Terms:
Trunback- the length of cable that is folded back onto its self making a loop where the thimble for the hook will be installed.
Spacing-distance between clips (not necessarily correct for smaller rope)
Don’t forget that the clip/clamp has what is known as a “saddle” and a u-bolt. The saddle is ALWAYS placed on the live end of the cable, not the turnback end, or “dead horse”. If you put the saddle on the dead end, then the u-bolt will be pressing and cutting into the live cable and will weaken it.
On the smaller diameter wire rope, “turnback” the proper length of cable, and place one clip “one clip base distance” from the end of the turnback. Tighten to torque specs. Place a proper size thimble in the loop end of the cable. Now place the next clip (on small cable there will only be one more clip) as close to the base of the thimble as possible, tighten to torque spec.
Excuse the way the table looks, but I cannot make it come out in columns.
Rope Dia, No. of Clips, Turnback, Spacing, Bolt torque ft/lb (unlubed)
5/16" cable, 2 clips, 5 ½" turnback, 1 7/8" spacing, 30ft/lb
3/8" cable, 2 clips, 6 ½" turnback, 2 ¼" spacing, 45ft/lb
7/16" cable, 2 clips, 7" turnback, 2 5/8" spacing, 65ft/lb
½" cable, 3 clips, 11 ½" turnback, 2 5/8" spacing, 65ft/lb
This is only the common sizes you might come across on the winches we typically use.
If you use shackles with your winches, don’t use anything less that ¾ inch thick on the bow, not the bolt or thread size. The ¾ inch thick bow shackle has a working strength of 9,500 lbs. on a straight pull; a 7/8 inch bow size has a working strength of 13,000 lbs. Also make sure your hook is of proper size. A slip hook (common hook, not the chain hook) with a throat opening of 1 11/16 inch is rated at 9,000 lbs safe working load on a straight pull.
Jerry D.
