Thought I'd try the electro tech's here first.
Recently acquired a 1965 FJ45 (bone stock) and decided I need some tunes. So I added an AMP under the seat running to 2 speakers behind the seats. Plug in my IPOD and I have tunes! Problem is, when I hit the turn signal, brake pedal, or any draw it lowers the volume like it's going to cut out then immediately back to normal. EDIT: Only the first draw... so as the turn signal is switched it cuts then stays normal even though the blinker is blinking.
I have a good battery, good grounds and a new OEM fuse block.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
