Amp guage question.
Bodean
Hot Damn
Brandon, MS
We recently replaced the spedo cable on a friends 40 and while the panel was out we decided to do the lighting fix. After reassembling the cluster everythng worked but the amp guage was showing discharge. We checked the alternator and it's charging. The truck runs fine but the guage doesn't read right. Any ideas?
Thanks!
Thanks!
Is it Garths old truck?
If so I'm not sure the ammeter is even wired thru the alt like OEM since it has the one wire GM on it, and a Painless harness I doubt it is........
Another thing to check is that the printed circuit is fairly delicate. When removing or re-installing, it is very easy to accidentally scrape some of the circuit board and cause open circuits or short circuits if you go at it with ham-hands. Gently set the unit back in place. This may have no bearing on your problem; however, it happened to me with my 42 and the ammeter was not working thereafter.
