Ammo Can Securement
metal?
mine have a latch and handle up front but nothing in the back, so either I'd have to weld some attachment(s) to the can or I'd have to use some sort of clamp going over the top.
If you have a bunch of identical ones you could have some sort of tray on the bottom and then one big transverse bar on top of all of them, that'd be fast enough to set up.
I've used ammo cans as well. I built a wood box that they would fit snugly into. Tried various ways to contain them. Tried bungees, then a metal strap, which both allowed for quick release to carry the ammo can away, but we're not secure enough on the trail. I ended up bolting it to a permanent mount. Bag to canvas bags again.
I will leave the wheel alone. Thanks for the tip.
Found one for bigger cans. I like bigger cans!
U.S. Military Surplus Triple Ammo Can Tray, New - 653499, Ammo Boxes & Cans at Sportsman's Guide
that pic is mostly about what not to do, I think: Straps look of questionable strength and the little can is really to fly off at any time with a good bump let alone a rollover... (And my experience with Sportsman's Guide does not inspire much confidence in some of their products, cheap as they may be.)
If you have a welder and a bit of time you should be able to weld the tray yourself for much less than $30 I would think, and with a better strapping system.
Come to think of it, my big cans have handles and latches on both ends IIRC, it would be easy to attach a turnbuckle or strap to those.
Honestly I think most of your worries are unfounded. Those racks were designed to be mounted in vehicles, I have experience with those straps and they are plenty stong enough for the purpose. Also it would be a simple matter to run a heavy duty strap under the mount before bolting it in place for increased security.
The small Ammo can next to the larger can looks to be an example of how different size cans can fit in the rack. (Not at the same time)
Also the rack is not a sportsmans guide product, it's a surplus military item.
