Ammeter Questions
Ventura, CA
Website
teqtach.com
I have an ammeter issue. Since I bought the truck two years a go, the ammeter has shown a slight positive amperage, even when the truck is off. It does not change when the car is off or on.
So, where do I start to find the issue? What usually goes wrong with these? Do I need a new gauge or is it a fuse, or something completely else?
I am going to be working on the truck all day today and tomorrow so let me know if you have any tests for me to run!
Thanks!
K
There are 2x 5amp fuses for the stock ammeter located in the same harness as the fuseable link (about 3-4" away from the link), this would be a good starting point. Also IIRC there is a diode or resistor on the rear of some ammeters that fails
hope this helps, and good luck
Great thread Marbles.
So. What I gleaned from that was that if my needle is slightly on the + side of the guage, even when the truck is off (and the battery is disconnected) then the gauge is toast... how hard is this to replace. What most likely killed it?
I did change the fuses and no difference. there was some rust on the connectors of the fuse contacts. Could this have hurt the gauge?
K
K
Does your needle flick briefly towards the negative when you turn your headlights on or "twitch" in time to your hazard lights?
If it does, and your only problem is that its "rest postion" (when neither "charging" or "discharging" is occuring - for example when everything is switched off) is slightly off to the right (+ side) - then maybe you can fix that by carefully "tweaking/bending the needle" somehow. (But I've never attempting such a thing myself.)
Cheers
Tom
Sodder It
I was in the same kind of situation you were with my Ammeter. I've got an 1983 Bj42 and the Ammeter was fried. It turns out it was wired wrong as a 1st problem and when I pulled it out to see about getting a new one I saw the copper wire in the back end off one of the post was broken. With patients and a steady hand I was able to sodder it back into the circuit. I don't know how long it will last but it's been good so far. Also if you think you have an ammeter that's telling you lies you can always check with a spare right on the bettery line and see if they match.
Hope I could be helpful
