Amazon Mud Flaps
arizona
Threw these on today. It took a bit of modifying to get the fronts to fit the LX, but should bolt right up to an LC. The rears bolted right up no issues. These are far more flexible than OEM so, the "rip off the rear bumper" thing shouldn't happen. I dig the look. I may paint them a similar color to the plastic cladding.
Amazon product ASIN B07B6NWLNR
Threw these on today. It took a bit of modifying to get the fronts to fit the LX. These are far more flexible than OEM. So, the rip off the rear bumper thing may not happen.
Here you can see what needs to be trimmed of the front flaps to fit. Basically an inch off of the outside edge and a new hole drilled.
You also need to remove a bit of the plastic cladding from the bottom. It's obvious when you look at it,
These don't come with the inside mounting bracket. You could run without them. I went ahead and whipped these up, top driver's side bottom passenger.
Truck side mounted to old running board mount holes.
