Am I Normal?
State of Flux...
On cold mornings...when I use my windshield washer fluid to clean off the windshield AND the heater / defroster is on, I get the smell of antifreeze through the interior HVAC vents for a few minutes. It seems the washer fluid drains down the windshield and into the cowl slots and then the smell begins. Am I normal? Any / all insight is appreciated
isnt that where the fresh air vents pull in air?
It would seem putting washer fluid in them while sucking in fresh air would explain the washer fluid smell.
Seems quite normal to me.
I believe it is set to fresh lately...with defroster / floor heater selection. It smells like anti-freeze...not washer fluid.
i smelled anti freeze with the heater one time - it was the heater coil - or whatever it is inside the cab that hot antifreeze runs through to heat air for heater...
Yup, it's never "normal" to smell antifreeze when the vehicle is running, or not.
If you do then, simply, you have a leak somewhere. It may be small, but it'll be a leak none the less.
Fred
Of course you're not normal, you drive a Landcruiser. That puts you above everyone else!:rolleyes:
But no, you shouldn't smell coolant with the heater, time to start troubleshooting!
Why do I only smell the slight smell of antifreeze after I wash the windshield with washer fluid and the runoff drains into the cowl? Could my washer fluid have an antifreezing component / glycol added to it and resembles the smell of antifreeze?
Yes, the washer fluid has a glycol content, that is why it doesn't freeze. You use it to spray the glass, so it doesn't freeze. Your wipers provide heat by friction, and the glycol antifreeze keeps the window clear. Then you spray and wipe the glass and Presto!
The same thing happens when I'm riding in the fourrunner; I usually keep it garaged so whenever I use the windshield washer in the cold i get the same thing. So I'm sure its just the washer fluid evaporating in the cold air.
