Am / fm radio - wiring help!
Riverside, Southern Cal
What's up guys...need your help. I found this radio from a 1979 Toyota Cressida? Anyways I can't figure out how to wire to my 1975 FJ-55. The radio has 3 connectors, first (blue) has 2 wires with blk & wht , second has 3 wires with red & blk & wht, third has 4 wires with 2 blks & red & wht. Any help will be greatly appreciated! Thanks! Jon
my guess is the bottom plug will be the speakers, white and the black above it will be one pair and red and black above that will be another. being from a cressida it might have a power antenna?? so that is (and im guessing) the blue plug. then that leaves the final 3 wires which should be power (full time power), ACC power (switched on via ignition) and the ground, 0Volts, earth, or negative if you please.
but that is only guessing. but thats where id start
Personally, I'd pay the local library a visit and see if they have a '79 Cressida wiring diagram!! You might be pleasantly surprised. I found the '76 FJ55 specific wiring diagram at the local library.
