1996 80 Series...Towards the end of a 40 minute trip last night I noticed my headlights dim and return to full strength. At first I thought is was my imagination but then it started to happen more frequently. Nearing home, as I started using my directional, my red battery light flashed briefly both times I used it. I'll also add that about this same time I threw a PO420 CEL. This is not the first time I have gotten this code, but I figure I have a rear 02 sensor on its way out as I had both Cats replaced two years ago.
At any rate, this morning I got out my multimeter and code reader (which is when I received the 420 code). I got a voltage test on the battery before I started it- 12.4 I believe. After I started it, 14.6 with the headlights on. I cannot get in behind the alternator to test it directly, but I assume with the over 2 volt increase it as working at least then.
Am I nearing the end of my alternator, or should I be looking somewhere else?
