Alternator
The Ghetto
Ok ok...so I finally had my new 72 FJ checked out for the electrical issue and the issue was.....yep the alternator and it's not charging my battery. I have a Chevy 350 conversion but I don't know what year so I don't know what alternator to replace it with. Any ideas?
there is an i.d. imprinted on the block somehwere. You can look for that and post it up here and im sure someone will know.
Well, I looked and all I saw was a firing configuration and that's it. Isn't there a somewhat universal alternator I could get or better yet...could I take it somewhere and have the core replaced?
Get some numbers off your block /heads and go to Mortech.com, should be able to find some info on your motor there. Al
If it is a standard GM alternator you should be able to get one just about anywhere. I changed my 40 over to a GM, cut several wires out of the harness, and it took care of some of my gremlins. but i am still running a 6 in it.
Lex
you need to find out if its internaly or externaly regulated ? are you still using your factory voltage regulator ? probably not. were do the wires plug into the alternator ? back or side ? heres a good sight with lots of info www.alternatorparts.com you should be able to ID it from this site and any auto parts place can get you one. good luck with it!
oh and the numbers to ID the block will be in front of the passenger side head on the block you may have to scrape paint/dirt off to see them but they wont tell you what alternator to use just what year the block is. the electrical could be anything or year depending on PO.
I found these but man are they expensive.
http://www.alternatorparts.com/Extreme%20Duty%20Dual%20Rectifier%20CS-144%20type.htm
Also, I took some pics of what I already have. Any ideas?
The red thing is my battery mount. The alternator is so easy to get to. It's right on the top left portion of my motor.
find the casting numbers on the engine and find what year it is, so you can do this the right and easy way. your eventually going to have to order parts for your engine and your going to need to know what year it is, so why don't you just find out now and save yourself some fawking hassle.
