alternator
slater,mo.
do most 1991 80s have the 80 amp alternator?what is the best way to remove and replace this alternator?thanks:beer:
80amps is what mine does after 3000 rpm.
Removal is not bad...disconnect the battery first.
1. remove the bolt, nut and air pump stay.
2. them at the alternator remove the adjusting lock bolt, 2 bolts and adjusting bar.
3. remove the pivot nut and pull the alternotor out.
hi
thanks frank.american toyota showed 2 different ones .a 80 amp and a 90 amp.i researched forums and found a post from cdan that said the 90 amp were very rare on 1991s.dans on vacation so i ordered the 80 amp.shouls be the correct one.hows much time is involved in swapping out the alternators?:beer:
First time I did it was on a road trip in front of the parts store in the middle of New Mexico in August. I was happy they had one. (it lasted 13 months)
...anyway I was parked in the shade no more than two hours.
good luck
