Alternator wiring
Cedar Park,TX
I have searched and found some links that may be helpful. I don't want to fry my old wiring. I am working through multiple wiring issues on my 71 fj40. The wires were disconnected from the plug while the plug was in the alternator. It is externally regulated. My guess is this is not a stock alternator? Am I missing a wire in the plug in the back? Right now with the engine running it is not charging the battery. It is only running off of the battery.
There are some amazing guys on this forum that know this stuff inside and out. I’m sure one of them will pipe in soon If not pm me and I’ll forward a bunch of helpful information they sent me. This one guy (living in the past) is amazing. He makes what is for me complicated, understandable.
There are some amazing guys on this forum that know this stuff inside and out. I’m sure one of them will pipe in soon If not pm me and I’ll forward a bunch of helpful information they sent me. This one guy (@Living in the Past ) is amazing. He makes what is for me complicated, understandable.
Fixed it so your compliment gets to @Living in the Past
Here is a wiring diagram that might help. The only question is on your regulator you have 2 wires attached to the field location. Why?
JP
This how it should be connected:
F= Field
E= Earth / Ground
N= not used.
B goes to battery
Somebody changed the wires? Because I see the White/Green is cut off.
Rudi
Thanks guys. I will look at this later today and see if that works. An entire wiring harness was cut along with other wires. There are several items that not work , but I am chipping away at it. I have not tested the regulator to see if that works, but it looks recently replaced.
While searching on headlight grounds, someone said there is a master ground wire for the headlights at the wiper switch? I have a bad ground that I am searching for the right side headlight. The left side seems to work fine though. Once fixed I will wire in a relay and put in halogen lights. These old lights are not very bright.
I am trying to get this to a point where I can drive it this fall once the weather cools down a little. It has been either hot and humid or rainy in Austin.
Thank you,
John
