Alternator Rebuild?
Medford, OR
Time to do some repairs with fall coming and looking to get my 91 reliable before heading off to no mans land in the cold. I'm finaling replacing the leaky radiator and the water pump that went out a month ago when things got a little warm. I've also got a weak alternator and curious to know if any one recommends having it rebuilt. Costs about $100. More than AM at the parts house but less than OEM. Also, any other repair recommendations while it's apart?
I'd say just call cruiserdan and get a remanned alternator. The amount you save isn't really worth it. The work alone; your time is worth more. What if you rebuild your alternator and it needs more work? Then this means you'll have to pull it out and redo the work. I know because I'm going through the same thing with my 92. Just do it. :cool:
My 2cents.
If you want it re-built, do it yourself. There should be a re-build kit available. Replacing the neccicary parts takes about 20 mins tops. I've never done my Cruiser, but have done lots of others. it's dead easy.
Not sure if its works for a 91 but I see a perfect opportunity to go with Photoman's alt mod and upgrade to the Sequoia 130/150A alt.
