I've read bunches and bunches of threads (including the Tundra/Sequoia upgrade threads) about alternators, and since I don't have time to do the 130/150 amp upgrade, i wanted to run something past this board for an opinion: I called a local shop about rebuilding the 80 amp, stock, Nippon Denso I have, and they said no problem. They even stated that they could "boost the output a little bit," up to about 105 amps. When I stated my concern about heat, reliability, etc., the guy said "with no more upgrade than that, you shouldn't have a problem at all. We'll be replacing the rotor, stator, bearings, and brushes, so everything will work fine."
I've worked on my own vehicles for 30 years, and electrical is definitely my weakest point. Therefore, every time I run into questions like this, I always ask those more knowledgeable than me.........what say y'all on this subject? I'd like to have more power from the alternator, but is that "upgrade" likely to give me problems? I have heard others on this board talk about getting 120 amps from their stock alternators with "no problems," but since reliability is my main issue, I need some advice on whether to do this or not.................
Thanks!
Thanks!
