Alternator re insertion help
LCyal8r
Jetty Crue
NEPA
I can do some stuff totally on my own. Needed a little help from my buddy to get my alternator out. It tested well, it was the battery the whole time. Well s***. Now I have to put it back in. I'm stuck at re inserting the top part into the bracket where there is that little metal piece that squeezes the top into place snugly so the bottom has some play on the tensioning assembly. Please forgive my improper terms.
Anyway, I am struggling to get the leverage necessary to squeeze that top piece into place so the long bolt can be run through it. Any tips or tricks?
The little metal insert highlighted below is my problem. The little bit of it that extends past the bracket makes it impossible to slide the alternator back in.
Put it into position then have someone use a long extension and hammer to drive it back in.
Hitting from underneath? IT seemed to create sideways motion when we tried that before.
You can do it standing next to the driver side fender. You just reach in from the top.
I Got it a little ways in, but it seems like I'm going to have to beat the hell out of the casing for the alternator to make that method work. And then it's also not quite lined up with the sleeve for the bolt to pass through. Is there any easy way of getting that stupid sleeve out a little bit towards the outside to allow the alternator to slip back into it's spot? Is this a common issue I'm facing?
A C clamp and socket is what i used to push that sleeve or busing forward towards the front of the motor. Hammers might damage it.
So my buddy who's a Toyota tech came over and wiggled it into place in under a minute.
I was both amazed and pissed. Now I have to lock it in and tension it up.
The lower tensioner bracket is only held to the engine with 2 bolts. remove them and remove the assembly.
Once out you will have more room. The alternator is meant to be snug in the top bracket.... you may need to get it kind of 'started' between the top brackets but not lined up, and wiggle the alternator back and forth with force towards the bolt hole. Once there is anything that resembles it lining up, use a screwdriver, awl, or any other tool you can to slide into the bracket through the alternator to help line it up. It's meant to be tight....
