Alternator Pivot Bolt--Nutless?
Dallas, TX
Fellow Cruisers,
I was replacing my PCV valve and saw my alternator pivot bolt looking out at me-it had backed out about 3 inches out of its mount!:eek:
Not a nice sight, as I've only had the truck a month and I'm planning to drive it from Texas to Colorado next week with my wife and dog. Me camping out a few feet of the highway--ok. Me and my dog--great. Me, my wife, and my dog? Failure. :o
So, besides staying awake at night wondering what other important bolts are backing out of their holes, I'm wondering if there's supposed to be a nut on the end of this bolt.
I tightened it down--but it's only turning in the hole, which appears threaded. Looks like the bolt is stripped, unless there is a nut that should be on the back end?
If i remember correctly, the pivot bolt (14mm head) threads into the alternator. There is no nut on the back. Its been a while since I did my headgasket and had the alternator off, so I could be wrong.
Hello!
I had the same problem about 2 weeks ago; unfortunately, I was about 100 miles away from home when suddenly a bunch of my dash lights turned on and the cruiser engine temp started to increase. When I stopped, I found out that the belts that drive the alternator and the water pump (are the same) were completely loose because of the alternator becoming loose. The bolt where the alternator pivots was stripped (no nut on back), and the lower bolt, the tensioning one, was broken. I guess the lower one broke because it was taking all the preassure. I solved the problem by using longer bolts, nuts, and locking washers. It is an easy fix and It will give you peace of mind, just get some grade 8 bolts.
Good luck!
am planning to pull down my alternator because of blinking lights and bumped into the ToyoDIY parts diagram for the alternator. i noticed no nuts on the pivoting bolt. i think yours got loose threads. do what bad80 suggested. get a longer bolt so that you could match it with a nut on the other end. that will hold the alternator firm
