Alternator Issue
Alternator repair update
ok, so I received some new parts from EBI. I spent the day pretending to know what I was doing with the alternator. After trying to be careful with the existing wiring harness, I decided to remove all the cracked wires and replace them. During the process, I replaced the brushes. My rookie mistake was that they really did not need replacing and I assumed that was the cause of the bad alternator. While replacing the wires, I found two problems, see pictures. 1. One wire from the stator assembly was dsconnected from the rectifier holder because it is barely long enough. 2. One connection at the rectifier holder was loose so I decided to add a bit of solder just below the paper thin washer.
Has anyone encountered this before? Is is possible to splice the wire from the stator with a solid strand of copper wire and then solder it to the recifier holder? Can I unwind the short wire from the stator? Also, are those diodes on the recitifier holder where the wires come together? Can they go bad?
I have assembled everything and am generally happy with what I was able to accomplish. I am a bit concerned about the one wire that barely reaches the recifier holder. I added a lot of solder and will know if it holds ok as soon as I put the shaft back in. I'm also unsure about the part on the retifier that was loose (movement up and down).
During the process, I also added a few new rubber grommets and replaced two screws from the recitifier holder that were worn. The screws without the grommets were able to move enough to wear the inside of the housing and the screws were heavily damaged on their sides which is not evedent from the pictures.
I am having the nut I need for the shaft machined and will let everyone know if I was successful. I was also thinking about having them machine a new aluminum pully because the heavy one I have is slighly damaged.
thanks in advance for you comments.
I've had good luck with fasters from facca... if they don't have it which they usually do they can get it...
I rebuilt my front axle with a lot of toyota fasters and paid out the azz I will never do that again... when they are not even a 10th of the price from a place like faca and they're the same grade and same cadium coating...
alternator rebuild
After trying and failing to find a machine shop that has the tooling to make metric nuts, I ordered two M20x1.5 left hand nuts from facca. Attached is a picture of the original nut from facca and that of the machined nut I had done at a local shop. Last night I completed putting the alternator back together and back into the bj. I let the battery charge overnight and this morning was able to start the vehicle fairly easily, looks like I have all my fuel issues licked as there was no air in the system. After letting it warm up a bit I shut her down and checked that nothing came loose, I also checked the voltage at the battery before and after starting. My volts at the battery before start-up was about 12.96 after start-up it was 13.00 and climbed to 13.01 after a few seconds. I
Of course, I still have problems...now with the starter. It has failed to engage several times during the entire time I have been having troubles with the alternator/fuel lines. It has 'clicked' and made a few other strange noises. At first I thought it was becuase the battery was not properly charged, but now am not sure what is going on. This morning, it cranked up fine because the battery was fresh. Unfortunately, I do not think I can diagnose my problems fully because the bj only ran for a few short intervals and then cut off. I think it cut off each time becuase it was cold and sat for a few months in my garage, I also did not have any way of keeping foot on the trottle while under the hood, my manual trottle cable is broken.
The bj is in front of my house a bit dejected and on the last attempt to start her, it felt like either the starter did not have enough power to crank or that the engine was seized, (noise made by a slow moving starter). I also forgot to mention that when having starter issues, I sometimes held the key in the crank position and nothing happened for a few seconds ( no noise, clicking), then it would start to crank.
any comments, suggestions appreciated as I have a little while longer to try to enjoy the summer with the bj and will have to ask for another inspection extension since I failed to get to the inspection station this morning.
Your starter issues sound like the typical starter contacts. Look at the diesel parts thread for part numbers. You will need the contacts and you might need the plunger. In a pinch you can get just one contact if necessary as one wears much faster than the other. It's an easy one or two banana job, just disconnect the battery before starting.
Starter repair, or not
I removed the starter today and discovered a few problems with the external and internal wiring, see attached pictures. I was able to repair the loose wire that someone had extended and wrapped around one of the screws that secured the cover over the internal contacts side of the housing. I cleaned all the internal components with rag to wipe off dirt, etc. I also greased the two bearings on both ends of the 'thingy'. I used electrical tape to repair the external wire.
After the install, there was no longer any delay after turning the key and hearing the starter plunger hitting the fly wheel. The starter did not spin however. Can someone tell me if I can remove the starter and test it to see if it is working properly; i.e., spins and has enough torque?
Because my problems seem to be snowballing quickly, I don't know if I am still having problems with the charging system and the starter is not getting enough power from the battery or if the starter is still broken. I do know I had 12.96 volts at the battery. I am letting th battery charge overnight and will try to crank the engine again in the morning.
Any ideas?
