Recently I had an electrical short from my rear heater that kept causing a fuse to blow and all the gauges besides the ampmeter to stop working. Windhield washer pump and 4wd indicator light also stopped working. Some wires got damaged and the rear heater wire got disconnected from the heater and had bare wire touch bare wire on the accessories wire (runs stereo, seat relay, arb isolator switch). The heater never worked so I wasn't sure which way was off and which was on, obviously the switch was on.
Now my ampmeter gauge needle flickers up and down a little at idle. It jerks around maybe 1/3 of the way, up and down. The voltage changed a little, but had no correlation with the flicker of the gauge (from 14.3 to 14.6V). It did jump up to 16V once but I couldn't get it to repeat this. Under load it goes up to 15.4V. Also, when under load the ampmeter needle is getting pegged all the up to the postive side. The battery has 12.4V. None of this every happened before. The only time the ampmeter gives a negative reading is when running major accesories, like the seats or compressor, when the engine is off.
Is this reason for concern? I don't know too much about this stuff and am trying to get the pig in better shape for a week long road trip coming up.
