alternator fix
philippines
i need help. am planning to remove the alternator to clean contacts due to flashing dash lights. could anyone link me to an existing thread on how to remove and disassemble it? i tried searching but none of the threads i have visited shows how to remove and dismantle. tried the FAQ but the only thing that came close was the starter project. hoping for your reply mudders.:steer:
binggo! i found the ToyoDIY.com through threads unrelated to this one and found the alternator diagram. looks like i could handle it from here since i did alternator fixes on other cars. thanks anyway mudders. wish me luck on this project. any tips though?
I'm not sure which engine you have but on my 1HDT, the cause of the dash lights flickering turned out to be the square connector on the alternator. It has 3 female spade connectors embedded in it and each of these were loose. They did not have enough clamping force to make a reliable electrical connection. That with some fretting corrosion gave me flickering lights nearly constantly.
Here's what I did: I pulled the square connector, bent the female spade terminals slightly so they would really clamp the male terminals in the alternator. Then I cleaned the inside of the terminals with some emory paper. Then I squeezed some dielectric gel in and reinstalled the connector. I also tie-wrapped the cable tight to the battery cable to minimize moving/fretting.
I haven't seen the flickering lights since, and my battery voltage stays up there no matter how many accessories are on. I suggest trying this before removing and rebuilding your alternator. 10 minutes work could save you 3-4 hours.
gee, thanks a ton finderscuba. i will try what you have suggested. but the thing is, mine would be harder to spot because the blinking lights doesnt happen too often. my dad drove the rig then noticed it once and reported it to me. this is my daily ride but i only noticed it once too. so i think the problem is in its early stages and wont be too obvious. if i pull out the terminal you are referring too and see no problem with it, i might go hard core and take the whole thing down. by the way my hdj81 comes with an 1hdt like yours
