Alternator died
Hopewell NJ 08525
A couple of weeks ago the alternator on the 80 started to act up . It would charge sometimes for a little bit then stop and the battery light would come on . I hoped it was the brushes as its got 160K on it and has eaten a good amount of crud thru the years .
Well that wasn't it , one of the tabs on the voltage regulator rusted thru that went to the brushes .
Looked up on line and found a new voltage regulator was $115 and while poking around on rockauto.com they had a brand-new alt on clearance for $115 with no core needed.
I got it and its a USA Industries #516003 and came with the dual pulley the fit and finish looks good . Bolted right up checked the output and it was putting out 60 amps at idle with and bunch of goodies on and a battery that was low .
I'll see how long it will last.
Pixs tomorrow of the unit and what died on the old one as the camera is charging tonight
heres some pixs of the new one next to the old ND unit . The last picture is where the tab that bolts down to the brush holder off voltage regulator rusted off making it unrepairable and needing at least a new regulator ,but since the bearing were getting a little noisy it wasn't worth me rebuilding it as the inside looked just as crappy as the outside of it too
Looking good mate! Had a similiar problem with mine when the brushes let go.
I might be due for a new one soon, like yours mine has filled with a whole heap of muck and is looking a little worse for wear. How much did yours set you back? - heard denso charge an arm and a leg.
How is the alternator treating you? Just found out mine is going bad. Trying to decide if I should spend $168 on a Denso replacement or save and get the one you have from Roick Auto???
So far so good .
but its only been a couple of weeks and 1K miles but it wasnt DOA out of the box or let the magic smoke out yet like a English car;) im happy with it
Update
The alt has been in for about 4 months now and all has been good but for one thing . When the temps get down the single digits it will not charge when I 1st start it up in the morning . I have to start the truck up and the battery light will be on. I turn off the truck and and restart it and all is fine for the rest of the day and will be fine unless it drops into the single digits over night . Not sure if it the alt or something else but I figured Id add this to the thread and keep an eye on it
I've been running a Mean Green for 6 years now without any problems. I recently posted a pic of my Odyssey Extreme battery install. The Mean Green has kept this 1100 amp battery giant charged and ready in 4 degree weather.....so far.
