Alternator Confusion
Richmond, Virginia
I have a 6 of 79 fj40 U.S. spec. I am having a difficult time finding an alternator that is rated for my year that has an external regulator (Current alternator bearings going bad). Amp meter is rated for 55 amps. From what I have seen by searching 1 of 79 was the last year for external regulators. So why does my truck have an external regulator? It's clearly a factory installed bracket on the fire wall and factory wire plug. I'm confused as to why my alternator is not internally regulated since it's a 6 of 79. Also does anyone know what the factory alternator is rated for a 6 of 79? I only run front and rear fog lights. No other accessories and no AC so I do not wish to upgrade the amp rating of the alternator. Thanks in advance.
hi @Idgie79 ,
a fact i can give u now is that bracket on your firewall is there for NON-USA Applications , like my 1983 FJ43L-KC still and did
originally a remote mounted regulator
Yes this helps a lot at least on the amperage question. But I am confused about the USA and foreign version of the truck and Alternator set-up. The truck has factory power steering, front disc brakes, factory roll bar, square turn signals, full seat belts, mph for speedometer, and 4 speed tranny. I thought foreign versions had drum brakes on all 4 wheels, lap belts, no roll bar, no power steering etc...This truck has not been restored or modified to accept any of the U.S. spec components.
door jamb data id plate ...
Is there a concrete way I can identify my cruiser as a U.S. spec or a foreign?
YES,
look at your drivers side door jamb , u should have one of these , if it uses or has the Word FEDERAL in it , it a USA
usa spec ...
Ok so that confusion is solved. Thank you. I also looked up an alternator from a 1980 fj40. I found a 50 amp with external regulator.
1985635
Sorry for the upside down pic. I looked up the 1980 because my 79 was built in June. I figured it would be close if not the same and it is the exact same.
awsome !
