I keep getting an occasional 420 code. The PO had the O2 sensor before the cat replaced, but not the rear. The receipt said the rear O2 sensor was slow to respond. There was another post on here about "lazy" O2 sensors throwing the 420 code.
So the question is, how do you test for that? The FSM just has the resistance check - which it passes. It takes a moment for the resistance to build, but does not appear any slower than the front (new) O2 sensor. This was tested at room temperature since the FSM tests that way (and I really didn't want to be near those cats when hot).
I'll likely end up replacing the rear O2 as PM, but those things ain't cheap. I guess I would feel better if I knew I was throwing out a defective part.
