Alt stud spinning
Jefferson City TN
anyone else have their alt stud spin causing you not to be able to tighten your connection causing all the dash lights to pop on and off?
I read all about people having it loose and tightening, but mine just snugs and spins.
Any ideas?
Ok, to what Alt Stud are you referring?
The wire on the back of the alternator??
The one that is on the adjuster?
The one on the pivot?
Or is this the ALTERNATIVE stud...
This is the stud that runs from the alt to the battery that has ring terminals on it.
Unfortunately,you need to replace the alternator. The
Stud should not spin, as there is a wire attached and it need the connection.
