alt charge at Idle
Silver Lake, MI
Well here is my problem I have little to no charge at idle most of the time actually a discharge situation. Once RPM's are up seems to charge ok. Is this normal or is my alt getting tired out. By the way this is a 92 w/ 80 amp alt with brand new interstate marine deep cycle battery hope to get some feedback thanx.
:hhmm: Tough to say. These alternators usually put out about 30% current at idle.
I used to be worried about mine, until one day I decided to put a voltmeter on the alternator's positive terminal... 14V right at idle. Just not much current.
How old is the alternator?
Assuming the battery is perfectly fine.....
AND ASSUMING THE BELT IS NOT LOOSE....
• Turn off all loads
• While cold, run a voltmeter from the (B) lug on the alternator to ground
• It should be between 14.0-15.0V
• Now turn on loads (like Hi-beams)
• With the engine warmed up and hi-idle (~2000rpm)
• Test again, should be between 13.5-14.3V
If both test fail you have a bad alternator.
BTW make sure to do it off the (B) terminal and not the battery. You could have a bad battery cable, corrosion, a loose cable, etc etc etc.
Ok will check at alt tomorrow, battery is new and charged after I purchased to top off. Belts good new and not slipping at idle on batt with only lights on at idle 12.4-12.6 batt , 12.7 no load:cheers:, 13.8 at about 2k with lights and htr blower on. hopefully this helps input so far has been helpful. thank you.
