Alt amps?
Adventure Teq
Liberty Utah
Website
www.instagram.com
So I've decided to rebuild my alt with this kit because I'm a cheap bastid.
Question is, how can I tell what amperage my alt currently is? With no markings is there any other way to tell? When it 'was' together would I have been able to test it while running somehow, how? My multimeter only detects 10amps. I'm thinking it's like around 80-85, just a guess.
Basically, being that I don't know the amps of it, before ordering this kit I need to know if the regulator and rectifier operate independent of whatever the stator and the rest of the unit's amperage is, or do they all have to match eachother? If they need to match, how the heck do I determine the amps of it so I can get the right kit?
I did email the seller asking if the kit would work regardless of whatever amperage it is, and explained that it's going into a 350 w/o AC, waiting for his response. Just want to hear you guys' input. Thanks.
The amperage should be stamped on the body of the alternator somewhere.
Don't forget the paperclip trick when you put the halves back together.
In order to test it when on the car you have to load the alternator to it's maximum capacity. The closest you can do without a load tester is to turn on all the accessories and see if it keeps voltage up.
You mean they don't have the little D shaped hole where you can use a paperclip to energize the alt to max output anymore?
I think it was possible to ground the field circuit that way and be able to tell that the alternator was working hard by the sound it made. Maybe there's a different way now?
Man I've searched this whole thing over, no stamps. I've searched for the rectifier I have and still couldn't find a rating. You mean the paperclip for the brushes right? ;) I'm on it. Thanks guys.
most if not all CS130's are 105 amp output. asking more than that from a stocker is going to burn it up. Rectifier will overheat.
Also, rebuilding the CS130 is a bitch. I broke 2 front cases trying to get the case/bearing/armature apart. Beware.
They are good alternators, got a bad rap early on, but almost all rebuild kits address the issue of the rectifier and rear bearing.
