Alright, who knows PIAA relays?
Eicca
Professional Noob
Utah
Alrighty, who knows PIAA relays? Little help needed
Uncle sold his '94 (curse him) and chopped the relay out of it before it went. Gave it to me. 'Nuff said. Now I've seen plenty of diagrams that apply to the Bosch relays, but I don't know how those compare to this one, so if somebody could give me some assistance, that would be awesome. Pics of said relay provided.
Here's the relay. Two main prongs, one smaller connection, and something I assume would be the ground connection.
Here's the relay with all the cut wires attached. I assume the big wire with washer thing hooks to the battery, the one with the black stripe splits and goes to the lights, and the smaller one runs to the switch and then to ground.
And here's a random close-up
Thank ye all much for your help.
Best person I know of would be Larry at Dirty Parts in Culver City. Does some wicked electrical work on lights and lots more. He's mostly on the Outdoor Adventure board tho. No affiliation - he did the PIAA lights install on my roof rack.
Home
Here's a WAG, can easily be confirmed with a 9v battery and a continuity tester (or test light).
Black wire with ring connector: Ground
Small white wire: signal 12v (connects to 12v through switch)
Large connector: relay switched power (one goes to battery through fuse, other goes to lights)
Gabe
So basically what I assumed to be correct may actually be correct. Sweet.
Thanks for the help. :beer:
