I have finally chased down and fixed all the leaks under my cruiser except one.
Talking about an Orion t-case here but it is essentially the same construction as a standard Toyota 4 spd t-case.
I think it is called the idler shaft, the one with two gears and no input or out put. It is secured in the case with a woodruff key and sealed with two O-Rings. In two out of two tries I have screwed up the O-Rings.
Any suggestions if I go for try #3? Or should I just clean it up and RTV the bejebsus out of it?
