Almost half way there- another headgasket thread
Well, I didn't have enough time to wait for Doug's DVD, so I went a head and got the head out using the FSM. The only thing that didn't go my way is that I wasn't able to get the two exhaust manifolds off the way you would like to, and I still can't figure out how to get the wiring harness off of the intake manifold. Here's some pics. I will be sending the head off to the machine shop tommorow, so they can check for cracks and to see if it needs a valve job. I wanted to post some pics of what I think is a crack, but I'm limited to only 3 pics. I was also wondering, since I can't pull my exaust up though the top, where would be the best place to cut it. I want to paint my two exhuast manifolds before I put them back in. :cool: I was thinking to weld the intermediate pipe back together after I drill out the studs holding it to the two manifolds. Has anyone ever had this problem getting the exhaust out? Also, my intake manifold has a lot of black nastiness inside. The wiring harness runs right through the middle of it, and down to the transmission somewhere. Is it easier to disconnect from inside the firewall, or do i need to disconnect it from the transmission. Or maybe I should have waited for the DVD.
Send that HG to CruiserDan when you get a chance.
-B-
Does he collect them? :grinpimp:
Maybe I'm misunderstanding what you're trying to do w/ the exhaust manifolds, but you can easily disconnect the manifolds from the pipes by using a 14 MM deep socket on to get the nuts off (there are 4 of them) and then using a Torx to get the bolts out. You have to do this from the bottom w/ about 26" of extension. Then pull the manifolds out the top. I just did this 3 days ago.
Oh, and regarding the intake manifold nastiness, mine also look really black and nasty inside. I'm just going to use some throttle body cleaner and some long/flexible dish brushes to get that stuff out. Apparently it's a REAL pain to take that wiring harness out, and if you can avoid it you'll be well served.
Yeah, I tried this but two of the nuts stripped on me. I used an inverted torx (t9) and it stripped on me also. Now I'm kind of like this:bang:. So what I want to do is find out where the best place to cut them is, so I can cut and drill of the stripped nut and bolts and put new ones. Thanks for the tip. I'll take your advice and clean the intake manifold on the vehicle.
I also tried to take out the exhaust manifolds and downpipe together and couldn't figure out how to do it (I was able to remove the nuts). If it's possible, hopefully someone will chime in with the method. Maybe a set of Craftsman bolt-outs would work after cutting the excess stud off. Other people have used them successfully on other nuts.
If you have zen like patience, you could go after those nuts with a dremel tool.
Maybe you could cut the downpipe just before the cat? Then you'd only have one pipe to weld back together.
Good luck.
Good luck.
I think I'm gonna cut it in the middle where the lower heatshield covers it. That way noone can really see my crappy welds. :frown:
Well, good news. The machine shop said the head had no cracks. They said it needs to be resurfaced and cleaned, but they reccomended getting a valve job. If I get just the cleaning and resurfacing it will be around $150, but if I include the valve job, then the price goes up to around $500. Do you all think I should get the valve job done while it's at the machine shop?
Just as a point of reference, the machine that's working mine over right now is charging $160 for the valve job, and $30 for the resurfacing. $500 seems really high ... or maybe that includes reinstalling the camshafts and adjusting the valves?
Well, he took the shafts to do the valve job, but I don't think I can put the head back on with the shafts on. :eek: $130 is a pretty good price. I chose this particular shop because they do the machine work for the local Lexus dealer. All the other machine shops I asked were only familiar with the old reliable (3fe). Kind of a hard to trust a machine shop that's inexperienced IMHO.
Yeah, definitely don't want to take a chance on a machine shop that's not experienced. Where are you located? Maybe something to do w/ your area as to why the price is high.
Oh, and to be clear, my number is $190 including cleaning/resurfacing and valve job ...
Oh, and one more thing, he doesn't need to shafts to do the valve job (grind/seals/etc.), but he does need them to do the valve adjustment. The shop here was going to charge $100 for the adjustment, but I'm going to attempt to do it myself if needed. I'm kind of hoping my clearances will still be in tolerance and I won't have to worry about it, but I won't know until I get it back.
