All the idle issues
TLDR: Used to idle high. Now it won't idle.
Just looking for where to start. I've been reading for a couple hours today and figured I would ask the experts to break down where I start.
It used to idle high and get progressively higher. I figured out the throttle cable was sticking a little bit and cleaned it up and no more problems. Let's call that 2 years ago and cleaned again 3-4 months ago.
It idled well, but has had mostly short trips.
This spring it idled pretty high 2000ish and I cleaned the end of the cable and the spring at the throttle plate. Seemed good for a month or two. The last two months or so it would idle rough in the middle of warming up and once fully warm (10 minutes of driving) it would be fine. The last month it would idle really rough and progressively got worse until it started dying.
I changed the oil (5w40) and cleaned the air filter Sunday. First start was great. Second start it stumbled a lot. Today, it wouldn't stay running without a fair amount of throttle and if below 700ish rpms a lot of throttle wouldn't bring it back up and it would die.
I'm going to check the intake hose as I've read plenty of folks saying start there. After that I've seen everything from distributor, plug wires, harnesses, IAC valve (holy s***s), headgasket, crank seals, etc etc etc.
Thank you for any help
Ummmm..........What year?
Have you or anyone that you know of removed the screws in harness on the VAF in the intake air filter line?
If yes, we're sorry for your loss.
If no, then maybe you're lucky and it's only a vacuum leak.
You really know how to put the fear of God into a Mudder.
I ran outside from work and checked. Screws are in. Hose is 3/4 split.
Thanks!
Thanks!
Well, There you go! It's the intake hose! They're still available new!
Absolutely do NOT remove those screws and try to remove that harness. I personally know of (2) people that did it trying to diagnose something else and managed to make it so their truck didn't run at all. Those are no longer available except used and they are $500. Used only on 93-94 trucks.
Start out with electrical tape and tape the bejesus out of the hose. If that fixes it, then you know it's the problem.
