Alignment
Taylorsville Utah
Alignment Q's?
I replaced the TRE's the other day and finally got around to checking the alignment, I measured the ends before I took them a part, But when I put it back together they were off quite a bit, After looking at the FSM I noticed in the FSM said the TRE should be aprox 47.5" and Relay rod should be 42.3" I did this as close as I could but it didnt seem to be correct.
I drove the 80 around the block and when I pulled it back in the garage I made sure I was going as straight as possible, From there I aligned the steering wheel to straight, By rotating the relay rod and I adjusted the tie rod in the rear so there was aprox 1/2" (somewhere here I read that 3/8" was correct)wider difference between the front of the rim to the rear, Toe in, Is this suitable or should I just take it in to have an alignment done?
Thoughts?
Thanks :cheers:
If you can afford it, have it done professionally. Be sure that it's right, and have someone else to blame if it's not. Just my $0.02
