Alignment Idea
California
Here's how I set the toe-in on my '73 FJ40. Mine has disc brakes, but I think this could also be done somehow on trucks equipped with drums.
I acquired some rare-earth magnets. They are super strong. Really just about any ones would work, as long as they are uniform in size, and in particular, thickness.
I also got my hands on two adjustable combination squares. It's best if they are identical, obviously:
img_0836-jpg.2661754
It's pretty much self-explanatory, as you can see. I used a length of aluminum channel sitting on the leaf springs as a reference bar:
I set my toe-in to just about zero. Just a very slight toe-in, as you may be able to see in the photo.
I just put BFG Mud Terrains on, and took it for a drive, and it seems to be great. I'm considering implementing my digital angle gauge to attempt to determine the actual angle.
Washers on tie rod end ?
Is that a no-no? I thought it might be although I'm not sure what the downside might be.
A couple things going on... Since these are FJ40 TREs going into mini truck arms, I had to use shims. The castle nut looked a little far down the thread to be in a good spot for engagement with the cotter pin, it seemed I had to make up some space.
The other thing is these are really old TREs, and they have been on and off several times, I am waiting to find out when I can get some new ones (welcoming suggestions on brands, etc.). So this is temporary.
