Alarm Problem
Zionsville, IN
My alarm will go off after 5 seconds of opening the door with the key. I never use the key fob(don't even know if it works) and always just lock the door from the lock/unlock switch on the door before I close the door, and it randomly goes off sometimes. I tried swtiching it to valet mode but does the same thing.
Alarm Question
I was finally able to find the CR1616 batteries for the alarm remote. Now that it works I have a question. The remote will unlock the doors and turn off the alarm and then I hit the button again and it will turn on the alarm but it doesn't lock the doors. Is this the normal operation or am I doing something wrong?
Is it the stock alarm? Mine locks/arms, unlocks/disarms. Stock alarm box, 95 80 series
Did you every figure out what was going on, my 97 LX 450 doing similar things.
Refering to this tread and the other alarm thread you have I would say try reprograming again. I do not know the full procedure. Maybe you have a loose ground or oher connector. That is causing it to not unlock.
On my fob, the top button locks/unlocks and arms/disarms with just one push. Two flashes of lights it's unlocked/disarmed, one flash locked/armed. Hope this helps, or just pull the pita out and get a viper or similar!
I might have a short, I think it started shortly after I installed my CDL and had the dash half off. But I installed the CDL switch 1 week after I got the truck so I don't really know if it did it before or not.
Does anyone have the procedure for resetting the alarm. I have had the batter disconnected for weeks at a time.
Also I only have one button on the alarm fob.
I would disconnect all the wire from the unit, clean the contacts, reattach. Does it have the glass break sensor? That all I could think of, good luck.
I was cleaning my car today with a shop vac. While cleaning under the driver seat I was face to face with the alarm module. The side facing the rear passenger seat, I noticed there was a button that read "reset". Please note I own a 94 LC.
