aircompressor vs paint gun compatibility
Billings, MT
I have spent the last couple of weekends prepping the front clip of my fj40 for a new coat of paint. Now it is time to spray and I am wondering if my aircompressor which is rated at 5.3 CFM at 50 psi will work with the paint gun that I just got which states on the box 9.5 CFM at 50 psi. Thanks for any help
I dont think your compressor will keep up. You could look at renting an auxilary air tank which will increase your volumen and allow you to keep up your CFM to the gun.
Just .02, and yes you really need to dry the air before you spray.
Rezarf <><
The 9.5 cfm figure on the gun is the minimum it needs to do a good job of atomizing the paint. Your compressor needs to be able to maintain that much flow whenever the trigger is pulled.
So your compressor isn't even barely adequate for that gun, and....that's a pretty low rating for a good gun. Is it one of Devibiss' "FineLine (I think it is - something like that) HVLP guns?
Most of the rest of the full size HVLP guns need more air than that to do their thing.
Many of the compressors available at places like Home Depot and such, however impressive they look and regardless all the numbers that are decaled all over them, are inadequate for painting properly.
HOWEVER, it's possible to paint with however much air there is as long as it's enough to make a spray. The result may not be professional but with practice a pretty passable job can be done.
My impression is that a real 5hp compressor is about the starting point for doing professional (or nearly professional) quality paint work. Additionally, you would want to have a cooler for the air as it leaves the pump, plus coalescing filter and regulator. The whole setup costs several thousand dollars.
That said, if you don't mind taking some extra time, you could spray it with a touchup gunlike this
http://www.sears.com/sr/javasr/prod...Yes&vertical=TOOL&pid=00915002000&tab=spe#tab
which only needs a little air. you would want to pick a day with low humidity. Plus you would want to use a paint that can be wet sanded (1500-2000 grit) and then buffed. These guns give a pretty good result, and sanding and buffing will make it turn out good.
Anyway, the gun you have may be just too big for your compressor.
I rented a high gasoline powered compressor. I also used a water filter and the paint job turned out well. I used a pretty good pro rated Iwata HVLP gun. If you plan on shooting decent paint with the expense of the reducer and hardener then it makes sense to use the right compressor, even if it means that you do NOT use the one you already own...
Max
