airbag replacement
Long Beach, CA
I'm just about finished putting my rig together after the collision. I'm looking to replace my airbag assembly on the drivers side.
I was at a wrecking yard yesterday and found a steering wheel and airbag assembly on a Lexus car, it looks exactly the same.
I'll probably go pull it tomorrow, I didn't have the right tools at the time. The steering wheel had an after-market rubber covre so it is in very good shape, mine is all torn and worn out.
My question though.....
my airbag light is still on in the dash, when i plug in the new airbag will it explode in my face?
How do I reset the system or sensor if anything..?
I just replaced both airbags on my 97. There is an airbag sensor/brain (can't remember what it is called) under the radio. I am pretty sure it will have to be replaced in order for the airbags to work and the light to go off. You might check on that at the salvage yard too. I left my battery unplugged for several days before messing with the airbags, I have heard you only have to do it for a few minutes but I wanted to make sure. I got both of mine installed, the drivers side was easy the passenger side was pretty difficult. I was a bit nervous the first time I hooked up the battery and started it but everything was fine.
Good luck
Rusty
