CodyRx7 said:BS. The damn thing worked about as good as the C.H. unit mentioned above. Even on the highest torque setting (1-4) I could stop the socket with my HAND after 2 uses.
That doesn't mean it isn't working correctly and at high torque. An impact delivers lots of small quick blows. If it runs up against something flexible it won't work. It will deliver a blow and rotate a small amount (slightly deforming the soft skin/muscle etc. of your hand), it would then rotate back to its starting point as your skin etc. retracted and then repeat. That's why using an impact gun on one end of a nut/bolt while using a hand-held wrench on the other doesn't work, you just keep vibrating back and forth.
Snap-On makes some cool torque setting extensions that work on this principle. They are basically like spring steel. Once the gun reaches a certain torque it will stop advancing the fastener since the extension will begin to twist each time the hammer/anvil hits and return to the starting point between impacts. I got the set and use them for all my lug nuts etc.
