Air pump control valve troubleshooting
Coeur d’Alene, Idaho
Does anyone have a simple diagnostic process to verify if the airpump is operating as it should? How about a theory as to the correct operation as to when air is pumped into the rail or bypassed.
Most importantly!
I am reinstalling the airpump system to try and pass emissions. For simplicity and my sanity's sake can I just route the pump outlet to the air injection rail and bypass the controll valve?
Thanks!
Chris
No can do. You'll get backfiring because air will still be forced into the ex ports instead of into the exhaust. Also, it bypasses air into the breather when the cat's too hot, so you run the risk of getting that thing red-hot during a long run, and ruining your cat or maybe even burning down your truck (maybe...)
And there's no simple test to see if the air pump is working that I know of. There's a SST that measures the pumps volume that a dealer uses. The air pump isn't about pressure, it's about volume...
60wag may have a better idea though. He's the 60's emissions rockstar around here.
Your post brings up a question that directly applies to my situation, Swank, but still might provide useful information for Chris.
While troubleshooting the air injection system in accordance with the emissions manual, I discovered that my cat sensor was bad, which ends up bypassing the air to the breather all the time. I "fixed" the problem my removing the vacuum valve that is controlled by the cat sensor from the system. The system seems to work fine otherwise since I did that. I am worried about my cat overheating, but I see no indication that it's occurring, and my interpretation of the cat sensor and it's function may be slightly different than yours. So the question at hand is:
Does the cat sensor bypass the air to the breather in case something goes wrong with the cat and it starts to overheat? OR Does the cat sensor bypass the air to the breather in order to help keep the cat from overheating?
To help with your question, Chris, IMO, there is nothing simple about it, but if you get the emissions manual and go through it step by step, it is straitforward.
As I understand it, the thermal sensor in the cat redirects air to the breather if the cat is getting hot. Adding air into the exhaust pipe only happens durring decel or if you're running cool and above 50mph. The rest of the time it goes into the exhaust ports which raises the exhaust temp and, if I recall, helps the cat do it's thing.
If your sensor is in the cat, not at the manifold (or slightly after) it's a thermal sensor and functions the same way. I think that once they FJ62 was introduced, they got rid of that and went to an O2 sensor like every other car on the planet...(we're just lucky, I guess) - I'm not sure about 40s, but I think this covers everything from 1980 - 1987 (not positive though)
If you're running cool, you should be okay though. Can you smell if after a long drive? (The cat, I mean)
Which valve did you pull out? The relief valve?
No no, I didn't remove the relief valve, although at one time that thing was actually stuck open before I replaced it. In terms of the emissions manual schematic on pages 3-19 and 20 (in my manual anyway), I bypassed VSV1. The only time VSV1 is supposed to be closed is when the cat temp is above 1445 degrees. When VSV1 is closed, ASV is closed, and the air has nowhere else to go but straight to the breather. I hooked a multi-meter to my cat temp sensor, and it's an open circuit, which means that VSV1 never gets 12 volts. That means that VSV1 and ASV never get to open and air always goes to the breather. So I bypassed VSV1 by unhooking the hose marked "F" on the schematic, and hooked it straight to the ASV, where the "E" hose was hooked up.
In other words, the ASV always thinks that the cat temp is less than 1445 degrees. I'm worried that the cat might get too hot on a long summer road trip, but like I said, there is no evidence that it is now. It doesn't smell or anything. I've even got this hi-tech, infared temperature measuring gun thing that I can borrow from work, and I've never been able to measure it higher than a few hundred degrees.
Ultimately, I'd like to fix it all back like it was. Aftemarket cats that accomodate the temperature probe are available and reasonably priced, but a new temperature probe is not.
My Bypass valve is bad too - what I've done is plugged up the bypass hose - so I'm doing the same sort of thing, only under s different set of circumstances.
Did you try unhooking the cat sensor? Seems like that would have the same effect without rerouting vac hoses. One reason I bring this up is because here in TX, if they look under the hood at your smog stuff and things are unhooked, they won't pass you for inspection...
We should keep in touch about it though - let me know if anything weird happens with yours and I'll do the same.
60wag - would love your input on this whole thing, if you're out there...
No, Swank, unhooking the sensor wouldn't have worked. That VSV1 that I was talking about needs 12V to open. If it doesn't open, air HAS to go straight to the breather. There is no way you could tell I did anything by looking under the hood, unless you spend every moment of your spare time working on your truck like I seemingly do. If you look at the schematic in the emissions manual again, all I did was unhook the hose marked F from VSV1, and the other end of the hose marked E from VSV1 where it goes into ASV. Then I hooked the hose that was marked F, and plugged it straight into ASV. I then took the E hose that WAS plugged into the ASV, and plugged it right back to the F nipple on VSV1. So VSV1 is plugged into itself, and there are no open nipples or unhooked hoses visible.
Thanks, and I'll definitely report any new "revelations".
So I am reinstalling my air injection system and valve. Problem is since converting to fuel injection I no longer have the stock air cleaner. Is it critical that the various pump hoses and vacuum hoses that are shown routing into the top of the air cleaner actually go there. Was this just a clean place to route them or is this actually a vacuum source?
Thanks for the help!
Cool. I'm right there with you - this air injection/emissions testing thing has been like a part time job for me for the last 3 months or so. And the thing is, the truck runs great! I'll be taking it up, trying to get it inspected again here soon...I may have it though.
Webster - That's a good question. I don't think those vacuum hoses that go to the top of the air cleaner are vacuum sources. If you look at the schematics for each of those systems, it appears that the vacuum comes from either the manifold or the carb and the hoses to the air cleaner are acting as vents.
I could be wrong - sure in the hell have been before ! ! !
Just figured it out
So after reading this thread I realized that the PO put an aftermarket Cat on my 60....he temp sensor looks like it was tack welded to the new cat to make it look nicey nice....so the VSV to the ASV was never opening and always bypassing air into the Airbox....so I went out did a little tinkering and did what was suggested in this post....now lots of air going down the air rail....here is my question....the above post is 3 years old....anyone have any issues with a HOT CAT....fire or anything else as a result of doing this.....I am interested to see what my numbers will be for my smog in a few months. Any info appreciated.
