I've pretty much decided I've got to do something about the rear sag when towing our troop's trailer. When I load up the back of the cruiser with my gear and that of 4 boys plus them, then add the trailer, I generally have only about 3-4 inches of clearance at the bottom of the weight distribution hitch and arms. I routinely bottom out and scrap the bottom of the hitch and arms. Even the weight distribution hitch is not helping much.
From search and past threads, I know several members here that tow love their Air Lift set up. For those folks, did you also install the Load Controller? With the Air Lift you've got to remove the coil spring during the install. Is it worth replacing the coil springs?? ??? Mine are original with 126K and the last three years have been abused with scouts and our trailer.
I don't want to lift the rear as I don't have a standard clearance in the garage. Maybe 1 or 2 inches at stock setup. I like the OEM ride, and the Rancho 9000 shocks I recently had installed allow for zero lift and I don't want to spend the $$ to replace them. New OEM coil springs, OME-which ones??? The OME heavy lift about an inch, correct? Expert opinion Christo???
BTW - I won't be doing the install myself. I don't have the
for it without someone there to direct. This is my daily driver, so I can't screw it up.
Any opinions, thoughts appreciated. I've got to do something before mid-May when we head up to Kernville for our rafting trip. I can't haul 4+ hours sagging like I currently do.
for it without someone there to direct. This is my daily driver, so I can't screw it up.Any opinions, thoughts appreciated. I've got to do something before mid-May when we head up to Kernville for our rafting trip. I can't haul 4+ hours sagging like I currently do.
