air intake ?
Battle Ground WA
I just recently put a full 3" exhaust system on my 96 lc. now that it exhales fine i want it to inhale the same. I can only find a drop in filter style from most of the major intake companys. so unless someone knows of some one who makes a cold air kit i was wondering if i just did away with the original filter box and put a k&n filter on the intake tube, would that help me in the power department. Or would it send the engine out of wack being as the increase in air flow. I really am not sure if this would work so your input wold be graetly appreciated.
thanks
K&N is not the way to go as far as air filters. Just about any thread here on the subject details the reason why they suck. As far as airflow, you want as much as you can get. You can't go wrong with pumping more air in. Thats why people are paying thousands here for turbos and superchargers.
And there is no off-the-shelf cold air intake for the 80 series.
The 80 already gets it's intake air from the coolest spot under the hood, inside of the fender. Moving it under the hood will increase the intake temp, a snorkel may reduce the temp?
I read a post on here a while ago where a guy was doing research on the subject. He did a before measurement on his intake air temp and an after snorkel measurement of the iat. He found that in most driving conditions he lost about 10 degrees with the snorkel. There is also the debate of the whole ram air deal but that, as to my knowledge has never been proven or disproven to have any real benefits.
thanks for the input i think ill get some measurments and run with it as long as no one sees any problems with the mass air flow sensor geting out of whack or anything like that
what are you gonna run with? remember the underhood air that you would get with a cold air intake type set up would be warmer than the air it already gets from the fenderwell. About the only thing that is gonna lower your iat would be to go the snorkel route.
These trucks are not rice rockets. You will get no benefit from doing your CAI mod. It already has a huge air box and gets the coldest air it can. Any removal of that system will be a detriment and not a benefit unless you're adding a snork.
I doubt that you would get any more air to the intake with a smaller filter. The stock filter surface area is huge, any smaller filter is probably gonna restrict air flow. That being said, nothing is gained from following the herd, so let us know how it turns out.
-Spike
Ditto on this. Rick did an outstanding job researching and designing this housing. It opens up the intake considerably. I am confident that the gains from doing this mod will significantly outweigh any other individual intake mods.
I agree. There is a night and day difference in the size of the stock MAF and Ricks. Plus it allows you to use an updated MAF sensor. I don't think any cold intake system could compare to it. A snork would be nice to catch a little bit colder air for the S/C.
