Air Conditioner Condensation Drain
Athens, GA
I'm having some water build up on the passenger side floorboard of my 96 FZJ80. I ran a good 5-6 feet of weed eater string through the sunroof drains, chased it with some water and a spray cleaner, and it ran clear, but it's still getting damp.
I found the AC drain hose that drains to the outside, and it is only like 2 inches long. Is that the right length? it makes sense, based on the aluminum heat shield/drain guide on the outside of the firewall, but it still seems short to me.
Second question- Is there supposed to be a gasket/grommet sealing this pass-thru? How do you all seal this off if you do water crossings?
Regarding the actual water, based on other threads I've seen, I plan to test the windshield gasket next I suppose. I put a rolled up paper towel about 6 inches below the AC drain setup and did not catch any condensation- is it possible that it is getting blown back in the car when I'm driving fast?
Thanks!
Yes, there is a grommet. Just reseated mine, which had become somewhat dislodged. I was also getting some moisture under the mat/carpet. It was hot today in the Northwest, and I ran the AC, and water actually poured consistently out of the little hose, and on to the heat shield. Hopefully I have cured my problem.
