I've been trying to trace a hard starting rough idle problem for months now.
Some background, Valves adjusted, timing bang on, Bosch primer installed, banjo bolt mesh filter cleaned at lift pump, I'm using standyne in the fuel. New fuel filter/ air filter. Water sedimented removed for now.
Yesterday I used some clear hose and worked my way back from the injection pump and fund there is a steady stream of air bubbles. I'd say 30/70 air bubbles to fuel though that ratio varies with different rpm. So I replaced all the hose clamps and hoses and still bubbles. dropped the fuel tank inspected the pickup, it was good, still bubbles. I have inspected all the hard lines and they seem fine, no leaks.
Question is, does anyone have any tricks to finding an air leak in a diesel system. Is there a vacuum test or something else I can try? Snap on has a vary expensive smoke machine that seems like it may help but it is 600 bones.
Thanks
Thanks
