Ahem...Ahem....Jeep Question.
TJDIV
UP of MI.
Mod Emeritus
UP of Michigan
Website
www.roamwherever.com
Helping 'Melancon' replace his front driver's side bearing [Hub Bearing I guess you call it]...
Got the Hub off, got the rotor off, and the back side of the inner bearing will not pop off the damn shaft.
Simple question really: Are they just that much of a bitch that I need a puller for it?
Thanks.
Tom IV
"prepping for his own front rebuild by warming up on a Jeep"... :doh: :D
Put the bolts back in, but not all the way, and use a large punch and hammer....it will come right out of the knuckle Tom...
Good luck!
-Steve
Isn't he asking about an inner race that is stuck on the axle stub? If so, maybe careful heat to the race only or grind/chisel it to break it?
Good luck!
-Steve
That works or get some choker chian and bolt both ends. Give the chine some slack and give it a mighty yank. THe force should pull everything free.
you very well may be correct!
I went down the uni-bearing path, thinking it was a newer TJ....
I have fought with them on my Dodge 3500 4x4....they are a blast. :rolleyes:
Used my astounding deductive powers from Tom's statement:
"the back side of the inner bearing will not pop off the damn shaft"
because I don't know the answer and am willing to gamble once in awhile just to look good to the newbs who don't know yet about my foot-in-mouth syndrome. :D
So what is it, Tom? No wait, I don't want to know.
uni-bearings will split and will 'appear' to be 'stuck' on the shaft, when in reality, it is stuck in the knuckle housing.
:beer:
I see said the blind man! I have messed with a uni-bearing and it did split and leave half the inner race behind. Had to use cold chisels and screwdrivers and kludge it off.
it was the inner bearing and I needed a gear puller to get it off.
had it tight to a breaking point and tapped it ONCE with a hammer and busted myself so hard in the nuts we had to take an hour break.
But it came off and the new shiznit went on without a problem. Works great and I even managed to not fxxx up his locking hub. [guess there's not that much to them though].
Thanks for the help.......
Yeah, I know.
Hell between the Mud Stickers on Wranglers and the Nut Shots from CJ's.......I don't know man.
Me and Jeeps just don't see eye to eye. [still a little sore today in the "area"] That thing really knocked me good....
