AHC pressure reading
Here's my update:
I followed the PADDO method and changed my AHC fluid. Pretty simple to get the old fluid out and new fluid in.
Then I followed the cheat sheet directions and cranked the torsion bar on the "low side", until the heights were even.
Then cranked both torsion bars three full turns. Pressures are now in spec and heights look good.
Got 11 gradations as well! Very happy to have done this job finally. The cruiser drives noticeably better. Nicer on turns, less bouncy.
When I was under there, it looks like the PO replaced the left torsion bar and both front globes somewhat recently.. And I think when they installed the torsion bar (looks pretty recent - still has stickers on it), they never evened things out.
Just to add to the collective intelligence on the AHC topic and for my own post mortem, here are my thoughts on the task:
  • Definitely put a lot of new fluid in the reservoir when bleeding and restarting the car the first time. I got super lucky that I didn't run out, but I was close. The second set of globes poured out clear fluid pretty quickly.\
  • If you're feeling up for it, you can totally syphon out the fluid from reservoir with a longer, clean hose. This was much faster than the turkey baster method. Plus, my turkey baster couldn't fit all the way in to get all the fluid at first.
  • If you're working in the cold like I was, keep a disposable coffee cup of boiled water around to warm up your bleeder hose with. The tiny hose I had could fit snug on the bleeder only after I got the hose hot. It would get cold pretty quick and stiffen up.
  • Cranking the torsion bars can be really tough. I used a 1/2" drive craftsman breaker bar. I wish I had some extra pipe laying around. I sprayed the threads with PB Nut Blaster and cleaned them the best I could with a wire brush. I wish I sprayed the PB when I sprayed the bleeders the night before.
  • The best position to crank them was lying under the car right in the center. I would put my left arm on the back axle housing and my right on the breaker bar.
Big congrats, welcome to the AHC maintenance club! Don't forget that AHC isn't quite like the Ronco oven (set it and forget it) - occasionally checking the pressures with Techstream and adjusting the torsion bars is a good thing to add to your oil change routine.
@CapnSpaulding, how did it turn out for you? Did you end up replacing your springs?
I seem to be in the same boat. Pressures are 8.8 and 7.0 for the Front and Rear respectively. I'm planning on doing torsion bars this weekend and seeing how that affects it. Seems like my front globes are "new", or at least, they look newer than the ones in the rear. I'm assuming I'm going to need new springs because they don't look replaced.
Ended up selling it, never got around to trying it. Probably worth a try at least.
