AHC line / Pipe replacement Procedure
I'm having trouble justifying so much expense to keep the AHC up and running. Started to investigate an AHC delete, but the options don't seem ideal. Came back around to the idea of replacing the line at the dealer, but the dealer is 2 hour drive away which complicates things. I haven't found a local shop that is willing to work on it. I need to investigate if the leak is really coming from the fitting (seems to be). Replacing an O ring and a spacer seems like I might be able to do my self, and could get me back in action for a while. l'm only moderately handy, but I have replaced the fluid in the system and the height sensors in the past.
I was in the same dilemma when I found out all my lines were rusted. Almost considered the conversion route but really liked the AHC system.
Hows the overall health of your system? If the components are not rusted out, I’d say it’s worth saving. A complete conversion will run you well more than a line replacement.
Got pics of the leak? A line is not hard to replace, just a PITA trying to fit it in.
Well I'll be darned; my local dealership said they're no longer available (Toyota dealership). I may take my chances with one of these overseas vendors as I can get a full rear set for the price of one versus dealership prices. Thanks for that info.
with pa
The lines are all available from your Toyota dealer as is the fluid.
I found with the closest Toyota dealership, part numbers is all they understand.
My front left supply line is leaking from where it fits onto the top of the shock. Is there a way to just replace the fitting without replacing the whole line? Are there washers that could be replaced to stop the leak?
Assuming your line and shock itself is not the culprit for a leak, there is an O-Ring and spacer that can be replaced. The O-Ring has to be installed inside the AHC line and the spacer is installed on the shock stud.
Such a wonderful thread.
Same problem as Judd and would LOVE to know if o-ring and spacer solve the problem.
Thanks so much!
Have a pic of the leak? Perhaps we can determine whether it’s a line replacement vs o-ring.
