I notice it when driving aggressively around a corner, but then it'll adjust while driving. I also notice it readjusting after a gas tank fill up from empty.I noticed my drivers side front was about 1/2" lower today than the passenger side, seems consistent across height modes. Has anyone else noticed a similar lean?
I did, it's a bit worse after a fill upI notice it when driving aggressively around a corner, but then it'll adjust while driving. I also notice it readjusting after a gas tank fill up from empty.
Did you measure from center wheel to fender flare?
Jesus what happened to Toyota. 1" lean in tolerance, 35% fuel trim bank to bank is fine. metal in the oil is ok now too. wtfUpdate, dealership stated 1" is the factory spec, so 1/2" lean is within tolerance
I checked mine in the L settings and it has been parked for about 2 weeks. All tires are on 36 PSIMeasuring from the ground to approximately the same place on the wheel arch, AHC normal height
FL: 34". FR: 35"
RL: 34 3/4". RR: 36"
I do have an awning on the left side, it overhangs a bit but it's only 50 lbs. Have the 10k service coming up, so I'll try my luck at the dealer then.
Curious to hear what the dealership ends up telling you. When I get a few minutes, I'm going to use tech stream to try to adjust the height offset.Measuring from the ground to approximately the same place on the wheel arch, AHC normal height
FL: 34". FR: 35"
I heard the same from a Toyota dealership when complaining about a lean on my old 200HE. It is not new thing with the 300s.Jesus what happened to Toyota. 1" lean in tolerance, 35% fuel trim bank to bank is fine. metal in the oil is ok now too. wtf
