I bought 4 new OEM globes on ebay for a little under $1100 and a few quarts of AHC fluid from my dealer (I had about 1/3 of left of AHC fluid that used to be in the metal can). I did it myself with the help of a few threads here on the forum and
@PADDO . If you go the DIY route, I would recommend a real ground down 36mm wrench, the 36mm fan clutch tool I bought on ebay and the 36mm fan clutch set I rented from Pep Boys had enough flex to give way and round off the globe. I bought a oil filter nylon strap wrench and a chain strap wrench to try to get them off but no luck, The chain strap wrench might have worked but the chain was too close to the wire loom for my comfort. I borrowed a ground down 36mm wrench from a buddy and with a breaker bar, I had them off. Mine were OEM that I think Robocop tightened, most people I read on this site had no problem taking theirs off (mine is a rust free California sample).
On the other hand, when I get in my 4Runner with the mods in my signature, I have a big grin. The feeling of a having a aftermarket off road suspension, upper control arms and heavier spring rate coils is a ride i'm used to, even my DD car has a modified stiff suspension. I almost rippped out the AHC, but my wife liked the idea of lowering and raising as needed. But after reading the pro's/con's of AHC, I decided to keep it and get it working properly. The ride is really nice, not floaty, even with my 10 ply tires. I leave it on the second level on the dial for most of my driving, that's the riding on the cloud level that people here probably talk about. I do set it to level one on really crappy roads and level three and four sometimes when I miss the firmer suspension feel.
