Aftermarket wheels
What changed yesterday?
What lift is this?
BP-51 with OEM spacer in front. Readying for that front bumper and winch!
Just trying something “new” to me with TRD rock warriors. I’ll probably order another set of TE’s but holding out to see if they’ll release 17’s for the Tundra and LC. They’re making them for the Tacoma and 4Runner right now but will make 17’s for us if there’s enough interest.
Obi, if you are running OEM spacers on top of the coilovers, you may need to remove some material from the spacer to allow the reservoir line 90 degree fitting to pivot up without contacting the spacer, during suspension compression.
Mine hit and jacked up the body where the fitting screws in.
Thanks for the heads up. I'll go check it out later as I didn't even think of that! I'm thinking of taking out the spacer too but may wait for the bumper before doing so.
I run Fuel wheels also, 18x9 with a 20mm offset...
@kreiten
Question? Are you running the Fuel wheels with or without spacers on the front? I ask because I am thinking about similar Fuel wheel (20mm Offset) but DO NOT want any spacers and wonder if they have clearance with the UCA. I have BP51 system and going to install the SPC UCAs when I upgrade tires and wheels. Please advise and thank you! Your LC looks kickin!
I don't run any wheel spacers, plenty of clearance with these wheels at the UCA, thanks!
18x9 Icon Rebound in bronze with 275/70 Nitto RG meats attached.
+25mm offset - no spacers needed at all.
