Aftermarket fuel sender issue - mimicking gauge issue
Tampa, FL
Just wanted to post this up for future MUDrs. Got an FJ62 this winter and have been slowing fixing it up. My fuel gauge has been reading empty - so based on threads on here I started diagnostics at the sender. I noted during removal the sender had no markings on it at all.
Pulled it out and float wasn’t stuck. It looked clean and fairly new. I checked the ohms and it was slightly out of spec at full but was close to factory recs and went up and down with float arm. I checked the gauge and it was moving with float arm appropriately. Now I was thoroughly confused. I reinstalled and noted it was tough to get it in the tank but eventually got it in. Sure enough gauge was reading empty again.
While removing it again I noted how it felt like it was binding on the arm. Came to conclusion it was bad design and arm must not be the correct length or angle. Got a new OEM and installed today. Sure enough - OEM arm is 4 inches shorter. OEM Fit in easy and worked perfectly. I’m sure this has happened to lots of owners - or they have replaced their sender and thought the gauge was the issue when it didn’t work. Here is a pic of the two senders. Toyota one on left.
