Aftermarket Cats?
Vail, CO
I need to replace the cats in my 97 lx-450. I want to cut out and weld in a universal converter. I know that some have used a magnaflo converter but I am not sure if I need one or two universal converters? I do NOT want to trigger the check engine light because of the second O2 sensor.
What have you guys done? Part numbers?
Thanks
I don't know the part numbers, but I have only seen people replace the 2 cats with 1 magnaflo. It probably won't trigger the CEL as long as you make sure that the 2nd O2 sensor is placed after the cat like it is from the factory.
Magnaflow 94006
Is this the part that I need if I only want to use one universal cat?
Now I have options. This is the other one that I found:
99006HM
Seems to be the bigger, cheaper one, yet still OBD2 safe.
The spun one seems to be the same, just smaller.
Thanks
I had Meineke muffler replace my cats with after market cats and have had no problems for the last 2 years.
magnaflow and don't look back!!!
i have installed many many magnaflow cats on many different vehicles and never had a problem with not being enough catalyst.
go with what was used by other mudders and become a magnaflow fan(all of their stuff is awesome)
Guess I should read up some more and search... but pre 95 do you still install both o2's or eliminate and fool it?
we just had a thread on this, one Magnaflow 94006 works great!
I just replaced the two stocks in my 95 with one 94006 and am very happy with the results, no CEL's and more gain
Have any of you noticed a reduction in passenger side floor heat with a Magnaflo cat?
