After the Engine Stand
Colorado
Looking for opinions on what to do with my engine now that it is mostly complete. Its on the engine stand now, but I have to attach the flywheel and clutch and bolt the transmission on to the engine.
Besides, its kind of a pain to have to push it around the garage when I need room.
Just looking for ideas.
Thanks,
Kirk
Do it when it is on the hoist. You can let it down on a piece of plywood juuuust a touch so that it wont wobble around when you torque everything down.
Where did you get your engine stand? Did you have to modify it?
Like Pinion said, except I found a solid block of styrofoam about 18 x18x 24" and that's what I rested mine on when installing BH and clutch. They use blocks like that to ship a bunch of trailers, stacking in between.
My engine stand is 1250 rated and has two legs in a "U" shape. Got it at CarQuest, about 120, IIRC. Nice and stable with the big six on it.
GL
Ed
Always use the U shaped engine stands.. The T shaped ones are Uber scary when a 2F is oriented straight up and down..
